    Hi JAZZ - yes absolutely, some way of fitting an end stop is very practical. I also realised that the "overhang", or working distance from the face of the dovetail jig, is only 91mm. So maybe I should extend the Y-axis rails by 50mm or so.
    Thanks for the links. If this is the type that hanermo2 uses, I guess that you will need 3 - or maybe the Pendant type is just as good?
    It seems I am getting close to having a mechanical design that will fulfill my requirements. However, there is still one point on my list that I need to look into. I would like to have some kind of adjustable bed. I will mainly be working with wood, so I think an MDF plate will be sufficient for that, and also with wood the fairly long Z-axis will not be a problem. But for aluminium I think it will be good to lift the bed for better stability. This bed could be smaller and also have provision for clamping the work material.
    Something like this:
    If anyone has come up with a mechanically good construction for raising/lowering the bed, I would love to have some info/links.
ID:	16184   Click image for larger version.
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. Aluminum router build - Could use some input
    By Tumblebeer in forum Gantry/Router Machines & Building
    Last Post: 01-09-2014, 09:48 PM
  3. My new, and first build....comments greatfully received
  4. Help appreciated
    By joncdrl in forum Milling Machines, Builds & Conversions
    Last Post: 17-09-2012, 08:34 PM
